cisco meeting server (SIP TO CMS)
siwar.ziadi1
hello, I try to install acano server (2.3) with cucm 11.5.1.13902-2, I followed the steps of instalaltions, I'm stuck in the conference Brgide (cucm level), the trunk sip is in FULL SERVICE but the conference not registered.
can you help me please!!!
Adarsh Chauhan
Level 3
Level 3
Hi Please refer to the following information
Rendezvous Calls
CUCM need to trust Callbridge Certificate as CUCM-Trust
Call bridge need to trust Callmanger Certificate
Adhoc Calls
CUCM need to trust Webadmin certificate as Tomcat-Trust
CUCM config
upload certificates of CMS:
web certificate as callmanager-trust
upload root ca certificate as callmanager-trust
restart call manager service and tftp service
configure domain and dns on call manager.
set up secure trunk with replace header checked
configure sip trunk
Add CMS in Conference Bridge under Media Resouces
also refer to:
https://www.youtube.com/watch?v=FFcGHWb718c
Please rate and mark correct if helpful
Adarsh Chauhan
Adarsh Chauhan
Level 3
Level 3
Rendezvous Calls
Adhoc Calls
CUCM config
configure sip trunk
also refer to:
Adarsh Chauhan
thank you for your answer and your explanation, good answer, it is a problem of certificate.
thanks again
