Cisco Roomkit Plus - Can I duplicate main output?
IsaacOwen1984
Hey
I want the second output to show exactly the same feed as the main output.
Just as a 1 in 2 out video distribution amp would do.
Will the software allow me to do that right out the box with no additional licence?
Isaac
5 Replies 5
Looks like the settings for what each monitor outputs are as the below.
I have looked at it yea and the only way i can think of making both HDMIs output the same is by setting the outputs as per the below. I can not see that it will be allowed though?
Video > Output > Connector 1 > MonitorRole: First
Video > Output > Connector 2 > MonitorRole: First
I do not have a codec to test this on at the moment.
Many thanks
Isaac
You'd think that would be the logical way to do it, however from experience you will have better luck if you set them both to "Second"
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
vincent gross
Hi Wayne,
I am supporting Cisco Room devices remotely. Can you please elaborate the better experience you had when setting the two MonitorRoles to Second? I'd like to know more before I make this change.  Thank you
Setting them both to "First" didn't give the desired outcome (of both screens showing the same).  Setting them both to "Second" did.  There's no harm in trying it to see if it works for you, then change it back if it doesn't.
Wayne
