Cisco Unified Video Advantage
michael1010
We have upgraded 2 systems to Cisco Unified Video Advantage 2.0.1.1 (cdp 2.0.1.0).
They cannot initiate video calls between each other but have no problems with video calls to systems running the older version - VT advantage 1.0(2).
any ideas?
8 Replies 8
michael1010
CAST Protocol diagnostics....
Successful call
12:29:02:851 RECV AudioStreamStart
12:29:02:851 RECV StationCallInfo
12:29:02:851 RECV StationCallState
12:29:02:851 SEND VideoFastUpdatePicture
12:29:02:851 SEND StationOpenMultiMediaReceiveChannelAck
12:29:02:648 RECV OpenMultiMediaReceiveChannel
Failed call
12:31:33:303 RECV AudioStreamStart
12:31:33:225 RECV StationCallInfo
12:31:33:225 RECV StationCallState
12:31:33:209 RECV OpenMultiMediaReceiveChannel
dtran
Level 6
Level 6
I am having the same issue. It's working perfectly fine between a CUVA v2 and a CUVA v2 but not between a CUVA v2 and an older version.
has anyone found the fix for this ?
Thanks !
Danny
reidg
hi, i'm having the exact same problem did you never get a resolution for this?
ta
There is definately a bug here, because I am having the same exact issue. I have looked through TAC case's, and have not been able to find anything.
jefflamour
Has anyone found a fix for this yet? I'm having the same issue also.
I found that the fix for this is to install the latest phone firmware. I found other messages relating to issues with older firmware and 7970's which fit my case. Firmware upgrade and restarting the PC running VT 2.0.2 fixed me right up. Hope this helps others.
carlbaccus
I had this same problem, I was using 7970 ip phones with the vt-advantage, and I needed to put in a new updated phone load. I do not remember which phone load it was, but it was in the 8.0 series phones loads. Give that a try.
updating the 7970 phone load to 8.0.4 sr1, fixed it for me.
