CMS WebRTC Chat does not work
Paul Freiberg
Hi all,
the chat function of WebRTC does not work. It is just displayed:
"You can't send messages to this conversation"
I tried it even with extern and intern parties.
Can someone help me?
5 Replies 5
Patrick Sparkman
The message board chat is disabled by default for new deployments starting with CMS 2.1, you will need to use the API to create a callProfile with parameter messageBoardEnabled set to true.
CMS API Guides
I will try it and response.
Same problem for me.
I tried to put messageBoardEnabled to true but no luck through POSTMAN.
Get option is not showing  messageboardenabled.
CMS version -2.1.5
Did you POST messageboardenabled = true to the callProfile node?
https://ip:port/api/v1/callProfiles
Did you POST the created callprofile ID to the  system/profiles node?
https://ip:port/api/v1/system/profiles
When using Chrome Postman, make sure you're using "x-www-form-urlencoded” format for the Body.
Thanks Patrick, I had the same issue and you spot how to solve it !
Enabling the parameter messageBoardEnabled to true let the chat happen now. However it require to re-schedule the space that are ongoing to get this. In my case, TMS is handling the scheduling and by deleting/creating the existing meetings, it works :).
