Codian 4210
hgraniteworks
Hi There,
We have a codian 4210 with a High Resolution key running version 4.1(1.59) we can get 720p dialing from a MXP but struggle to get 720p from a Polycom group series system.
Does a later software release fix this issue? or is this a bug betwen the codian and new group series codecs?
Shaz
24 Replies 24
Does the config look ok
This is currently how i have mine configured. One more question what media port protocol are you using right now? SD/HD/HD+?  I know you said your other systems connected fine but i am curious.
Pretty much the same as your config, I will still ugrade tomorrow and let you know the outcome, also will I be ok to test your endpoints once I complete the upgrades?
I do not have the option for media port as I am on a 4210 not 4500 series but I do have the HR option installed in order to achieve 720p
Shaz
ah! Yes, of course you can use those endpoints to test.
Fantastic, Thanks a lot!
There was a reported bug in this area in MCU SW.  Hopefully your able to update to 4.4 (3.54) at least.  See
CSCue55707.
VR
Patrick
Hi Patrick,
Many thanks for your reply. Does the below apply for the 4200 series.
Many Thanks
CSCue55707.
VR
Patrick
From what I understand it affected all platforms.  4.1 is quite old.  I know this affected the other series MCU's, so more likely yours to.
VR
Patrick
hgraniteworks
Hi Patrick,
Only option is to upgrade to 4.4(3.54) by the sounds of it, will let you guys know the outcome tomorrow.
Shaz
Thanks for your assistance it look likes 4.4(3.54) did the trick I was recieving 720p from the group 300 on this version.
Shaz
