Cube Video call hold resume issue
jeroenhermans
Level 5
Level 5
I'm setting up a test environment to allw video calls to pass trough a cube.
9951 - cucm - sip trunk - cube - sip trunk - cucm - jabber for windows
I was able to get it to work for both audio and video, but as soon as I put the call on hold and try to resume, the call is dropped.
This is the relevant config :
voice service voip
ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
allow-connections sip to sip
sip
  midcall-signaling passthru
  pass-thru content sdp
dial-peer voice 1000 voip
description Inter_Customer_Inbound
session protocol sipv2
incoming called-number +4924141250061
dtmf-relay rtp-nte
codec transparent
no vad
dial-peer voice 2000 voip
description Inter_Customer_Outbound
preference 1
destination-pattern +4924141250061
session target ipv4:192.168.12.2
dtmf-relay rtp-nte
codec transparent
no vad
dial-peer voice 2001 voip
preference 2
session target ipv4:192.168.12.1
dtmf-relay rtp-nte
codec transparent
no vad
Attached is a debug of call put on hold and resumed. thanks for your help.
Jeroen
Fatih Cetin
Hello Jeroen,
I have almost the same problem. Did you find a solution?
If I chose media flow-around in CUBE it works fine (But I need media flow-through). Did you try to use media flow-around?
Fatih
I resolved it by using h323 instead of SIP. It turned out that our gateway (2800) was not capable of runing the IOS version that was required for SIP to function in our scenario.
Rgds,
Jeroen
