custom Conference IDs on MCU 5300
j-ackermann
How can I define the conference ID used by a Cisco 5300 MCU? It  automatically assigns IDs from 400 on for ad-hoc and from 2100 on for  reserved conferences and registers them on h.323 and SIP. They are also shown in TMS but are not changeable. Is it possible to assign my own values?
Thanks a lot,
Patrick Pettit
Hi Jochen. If you navigate to the mcu in systems navigator, click on settings>edit settings>extended settings, you should see First Meeting ID step. You should be able to change it there. Let us know if this is what your looking for. Thanks.
VR
Patrick
Sent from Cisco Technical Support Android App
Patrick Pettit
VR
Patrick
excellent, that did the trick.
thank you
