04-19-2022 03:37 AM
Hi Team,
One of our customers has had a scanner pickup CVE-2011-1473, is there any fix for this.
Kind Regards
04-19-2022 03:51 AM
You can check it on your own with the Bug search tool, to see if this CVE is affecting the Expressways in general and which specific versions.
If there is an entry, then you will find all the info that you need (also, if there is a fixed version).
Log in to Community
