03-13-2018 02:39 AM - edited 03-18-2019 01:57 PM
Hello!
I'm using CMS with CUCM
I've enabled participant labels in CMS, as far as I understand label is taken from ASCII Display (Caller ID) field set for the line of device. Is there a way to make CMS show label from Display (Caller ID) field, so that the label is shown in Cyrillic letters?
Solved! Go to Solution.
03-13-2018 05:15 AM - edited 03-14-2018 05:03 AM
Check the “Transmit UTF-8 for Calling Party Name” on the CUCM SIP trunks facing CMS and reset them (which drops all calls).
03-14-2018 12:10 AM
12-11-2020 03:13 PM
for hebrew characters, the CMS presents the string as mirror writing.
do you know about bug on it?
