Delete contacts from TMS phonebook
desmondallen1
How do you delete a contact from the phonebook in TMS? I have a user who's extension is showing up twice along with his mobile number.
Version 15.1.0
PJMack
Level 7
Level 7
You need to go into TMS and find out what the source is for that phonebook, or if you have multiple phonebooks assigned to that endpoint check those sources, perhaps that contact is in both sources?
