Does TC7.3.3 Encrypt PC Source 3 on the C Series codec?
Luke Sykes
Hi All
I have a client who just upgraded their C40 from 7.1.1 to 7.3.3 and now he cannot share PC which is connected to DVI Source 3.
Does TC7.3.3 do anything to the input?
Many thanks
Luke
Hi Patrick
Thank you for your reply
I have since discovered that the client was using a splitter to send the PC signal to a monitor for local presentations and also to the codec for VC presentations.
Removing that fixed the problem!
Thank you again
Kind Regards
Luke
Patrick Sparkman
All of my C40s are running TC7.3.3 and all of them can present and share content through the DVI input.  What does the codec say when you try to present something?  Does anything show up in the logs?
Hi Patrick
Thank you again
Kind Regards
Luke
