Downgrade from TC6.01 to TC5.1.5
Wee Teck Ng
I have recently upgraded a C20 and EX60 to TC6.0.1 from TC4.1.4 and TC5.1.4 respectively. As per customer requests, I was then ordered to have them downgraded to TC5.1.5 for both units.
After the downgrade, I am unable to access the web interface for both units. Either using http or https. I can make calls and telnet to the codecs. After telnet-ing to the codec, I have checked that both HTTP and HTTPS are turned on under network services.
What could be the problem?
Ravi Yadav
Level 4
Level 4
Hi Wee,
There should not be any such issue.
What do you get as the error on the web browser . As mentioned there is no such known issue however if it is still happening try accessing on any other browser. That should be fine.
Else do a hard reboot to the codec
Let me know if that works
Ravi kr.
Sent from Cisco Technical Support Android App
Hi Ravi,
I dont have physical access to the unit. The below is the error I got. However, if I perform a selectsw to the TC6.0.1 image, I am able to web into the codec again.
This web page is not available
The web page at might be temporarily down or it may have moved permanently to a new web address.
Error 103 (net::ERR_CONNECTION_ABORTED): Unknown error.
are we "listening" to the http/hhtps ports?
If you have root access you can do :
[BGL-SX20:/tmp] $ netstat -apn | grep lighttpd
tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1387/lighttpd
tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1387/lighttpd
tcp        0      0 127.0.0.1:8093          0.0.0.0:*               LISTEN      1387/lighttpd
tcp        0      0 :::80                   :::*                    LISTEN      1387/lighttpd
tcp        0      0 :::443                  :::*                    LISTEN      1387/lighttpd
unix  3      [ ]         STREAM     CONNECTED     4355   1387/lighttpd
[BGL-SX20:/tmp] $
Are we listening to the ports 80 or 443 ?
thobonho
Hi Wee,
It could be that your TC5.1.5 pkg file is corrupted  since you're experiencing this issue on several systems. I would suggest  you to download it again and to re-apply the update; maybe check the  md5 checksum before to proceed.
