Downgrading an SX10N to TC7
jasoncbci
I have an SX10N that is currently on CE8.2.1 that i would like to drop to TC7.3.X. I've tried downgrading to TC7.3.7 and 7.3.6 but i'm faced with the same issue. There is no audio that comes from the codec. Once i upgrade back to CE8.2.1 everything works fine. Is this a known bug? Is there any way around this?
Thank you!
If I am not mistaken, you should have an option called "AudibleAndAudioPairingSoundRouting"  under Experimental Audio Settings. Just make sure it it set to HDMIand LineOut instead of Split.
Shashank Mahajan
This issue is due to a known bug CSCvb27626.
Workaround suggests performing a factory reset while it is on TC7.3 or re-upgrading to CE8.x.
Permanent fix is expected in CE8.3.x.
