DX80 Ldap user Management
Ayodeji Okanlawon
Gents
I am trying to use the LDAP integration feature in CE8.2 for user management on our TP endpoints. I am not having any luck with this. I have enabled LDAP configuration as follows, but I dont even see the DX80 attempting to query LDAP for the login.
Is there anything I am missing?
Please rate all useful posts
8 Replies 8
Patrick Sparkman
Are you using the correct port?  Make sure you're using the correct port and encryption setting for your AD server, check the admin guide for details on these two settings.
What if you change your Base DN to: DC=corporate,DC-lab,DC=com.
Try removing the Admin Filter and use just the Admin Group.
There isn't much in the logs, but you can check auth.log to see if you get successful or failed login attempts.
Thanks Patrick. The port is correct same port ad I use on cucm integration with LDAP. The with log doesn't even show the unit attempting to contact the LDAP server. I will try and change the base DN.
One question is this do I need to add tgr user on the TP until first and aff it to Admin group?  I did try this as well and still no luck
You don't need to add users to the endpoint, when a user authenticates via LDAP, they'll login as an admin, but they don't get added to the endpoint's user list.  Make sure you're logging into the web interface as domain\username.
This was my issue. Used domain\username and worked - thx
Thanks Patrick. I am not having any luck with this. The LDAP setting I am using is what we are currently using on CUCM which works. I have tried to logging using domain\username. I have changed the base DN as you suggested..It will be nice to see if the TP actually sends a request to the LDAP server. On the auth.log it just shows authentication failure, which looks to me like it was trying to do a local authentication as opposed to LDAP
Try the typical AD port 389, instead of 3268.
i used below setting and its worked for me :)
