ESXI Host update on BE7000
VCsupport17
Level 3
Level 3
Dear Community,
We have BE7000 Medium size with Collaboration apps running and working fine. The BE7000 server has EXSI 6.5 as factory default version when delivered and installed and with collab apps running 12.5 (CUCM, IMP).
Is there any problem if we will update the ESXI version from 6.5 to 6.7 or 7? What is recommended?
Thanks!
You can use 6.7 or 7. Both are supported.
Remaining applications you can check by yourself from below link.
https://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/virtualization/cisco-collaboration-virtualization.html
Response Signature
