03-21-2018 08:14 AM - edited 03-18-2019 01:59 PM
Hello
my EX90 keeps losing its SystemName. What can I do about it? regards, Eric
03-21-2018 11:28 AM
Do you have TMS? You can backup the good config and set TMS to restore it on a regular basis.
What version of software are you running on it?
03-21-2018 02:49 PM
hi PJ
thanks for the reponse.
No TMS
the SystemName is deleted at every reboot. So a restore after every reboot for just one setting is a bit overkill.
Software version TC7.3.9.b938c8e.
regards
Eric
03-21-2018 03:42 PM
Is it registered to CUCM? If so, have you set the system name in CUCM? And if so, does it have any weird special characters that maybe CUCM doesn't understand?
04-15-2018 09:54 PM
Has someone enabled Non-persistent mode for the configuration of the endpoint, so it keeps reverting to the saves state when it is shutdown or rebooted?
Check in the web interface under Configuration > Security > Non-persistent Mode
Please remember to mark helpful responses and to set your question as answered if appropriate.
