Expressway E and C cannot sign-in
samhopealpha
Level 2
Level 2
Hi everybody,
I am eatablishing Expressway MRA with CUCM
CUCM 11.5
Expressway X8.8.1
EXP-E is using Dual NIC, one for internal, one for external
Example:
VoiceServiceDomain: production.com
ServiceDomain: lab91.local
here is the connection
CUCM ---(tcp)---- EXP-C -----(tls)----- EXP-E --- Firewall --- Jabber Mobile
Jabber Mobile: Phone service only
  • The zone of Unified Communications traversal, between C and E are ACTIVE
  • The zone of Neighbor with CUCM, between C and CUCM are ACTIVE
  • External DNS are done and tested
_collab-edge._tls.production.com: 10 10 8443 vcs.production.com.
  • Internal DNS are done and tested
_cisco-uds._tcp.lab91.local: 10 10 8443 cucm91.lab91.local
  • jabber-config.xml has been configured
<VoiceServicesDomain>production.com</VoiceServicesDomain>
Jabber mobile has been successfully registered to CUCM via internal wifi network
However, when trying to sign-in jabber mobile via Internet, it returns "Cannot sign in"
In jabber.log, it seems cannot connect to CUCM ? or I have to investigate in other area?
2016-09-15 12:51:04,023 INFO [0xdafba930] [control/CallControlManagerImpl.cpp(1874)] [csf.ecc.evt] [notifyConnectionInfoChange] - CONNECTION_INFO_CHANGE: size(5):
type=eUDS, isRelevant=true, server=10.10.242.91:8443, connectionState=eFailed, isEncrypted=true, failureReason=eTimeout
type=eCCMCIP, isRelevant=true, server=10.10.242.91:8443, connectionState=eFailed, isEncrypted=true, failureReason=eTimeout
type=eEMAPI, isRelevant=true, server=10.10.242.91:8443, connectionState=eNotApplicable, isEncrypted=false
type=eConfigFile, isRelevant=true, server=10.10.242.91:6970, connectionState=eNotApplicable, isEncrypted=false
type=eConfigFile, isRelevant=true, server=10.10.242.91:69, connectionState=eNotApplicable, isEncrypted=false
2016-09-15 12:51:04,023 ERROR [0xdafba930] [nts/ecc/src/config/CCMCIPClient.cpp(138)] [csf.ecc] [fetchDevices] - HTTP error: eTimeout
2016-09-15 12:51:04,023 ERROR [0xdafba930] [nts/ecc/src/config/CCMCIPClient.cpp(139)] [csf.ecc] [fetchDevices] - Request failed : "https://10.10.242.91:8443/ccmcip/Personalization"
2016-09-15 12:51:04,024 ERROR [0xdafba930] [c/src/callcontrol/Authenticator.cpp(320)] [csf.ecc] [authenticate] - authenticate() failed [eCouldNotConnect]
2016-09-15 12:51:04,024 ERROR [0xdafba930] [lcontrol/CallControlManagerImpl.cpp(745)] [csf.ecc.api] [doAuthenticate] - doAuthenticate() failed [eCouldNotConnect]
2016-09-15 12:51:04,024 INFO [0xdafba930] [control/CallControlManagerImpl.cpp(1781)] [csf.ecc.evt] [notifyAuthenticationStatusChange] - AUTHENTICATION_STATUS_CHANGE: eFailed
2016-09-15 12:51:04,024 INFO [0xdafba930] [lcontrol/CallControlManagerImpl.cpp(755)] [csf.ecc.api] [getAuthenticationStatus] - getAuthenticationStatus() = eFailed
2016-09-15 12:51:04,025 ERROR [0xdafba930] [ntrol/TelephonyCallControlImpl.cpp(1620)] [jcf.tel.callcontrol] [authenticateWithCucm] - Failed to authenticate with CUCM AuthenticationStatus: [eFailed]
2016-09-15 12:51:04,025 ERROR [0xdafba930] [ntrol/TelephonyCallControlImpl.cpp(1621)] [jcf.tel.callcontrol] [authenticateWithCucm] - Failed to authenticate with CUCM Authentication Failure Code [eCouldNotConnect]
2016-09-15 12:51:04,026 INFO [0xf775eb4c] [ices/impl/TelephonyServiceImpl.cpp(1991)] [jcf.tel.service] [onTelephonyServiceAuthenticationStatusChanged] - TelephonyServiceAuthenticationStatus has changed from [None] to [CouldNotConnect]
2016-09-15 12:51:04,030 INFO [0xf775eb4c] [lcontrol/CallControlManagerImpl.cpp(771)] [csf.ecc.api] [getLastCCMCIPServerUsed] - getLastCCMCIPServerUsed()
2016-09-15 12:51:04,031 INFO [0xf775eb4c] [c/src/callcontrol/Authenticator.cpp(609)] [csf.ecc] [getLastCCMCIPServerUsed] - getLastCCMCIPServerUsed() =
2016-09-15 12:51:04,032 ERROR [0xf775eb4c] [ice/TelephonyAdapterServerHealth.cpp(66)] [jcf.tel.adapter] [getConnectionIpProtocol] - No connected ConnectionInfo of type: [eSIP]. Could not determine connection IP Protocol
2016-09-15 12:51:04,033 INFO [0xf775eb4c] [lcontrol/CallControlManagerImpl.cpp(911)] [csf.ecc.api] [getLastCTIServerUsed] - getLastCTIServerUsed() =
2016-09-15 12:51:04,033 ERROR [0xf775eb4c] [ice/TelephonyAdapterServerHealth.cpp(66)] [jcf.tel.adapter] [getConnectionIpProtocol] - No connected ConnectionInfo of type: [eCTI]. Could not determine connection IP Protocol
2016-09-15 12:51:04,034 ERROR [0xf775eb4c] [ice/TelephonyAdapterServerHealth.cpp(66)] [jcf.tel.adapter] [getConnectionIpProtocol] - No connected ConnectionInfo of type: [eCTI]. Could not determine connection IP Protocol
2016-09-15 12:51:04,039 INFO [0xf775eb4c] [(0) ] [JABBER.TELEPHONY] [OnAuthenticationStatusChanged] - OnAuthenticationStatusChanged: CouldNotConnect
2016-09-15 12:51:04,041 INFO [0xf775eb4c] [e(0) ] [JABBER.TELEPHONY] [setTelephonyError] - telephony life cycle, set error to 3005
2016-09-15 12:51:04,043 INFO [0xdafba930] [ntrol/TelephonyCallControlImpl.cpp(1640)] [jcf.tel.callcontrol] [authenticateWithCucm] - <--
2016-09-15 12:51:04,044 INFO [0xdafba930] [/TelephonyAdapterAuthentication.cpp(193)] [jcf.tel.adapter] [Authenticate] - <--
2016-09-15 12:51:04,044 ERROR [0xdafba930] [s/impl/AuthenticationHandlerImpl.cpp(75)] [authentication-handler] [AuthenticateImpl] - Authentication Failed
2016-09-15 12:51:04,051 INFO [0xf775eb4c] [rc/framework/ServicesDispatcher.cpp(174)] [services-dispatcher] [nextTask] - Task queue is back to a safe size
2016-09-15 12:51:04,056 INFO [0xf775eb4c] [common/CertificateValidityCache.cpp(172)] [csf.cert] [clear] - Clearing accepted and rejected certificates from memory
2016-09-15 12:51:04,056 INFO [0xf775eb4c] [ervices/impl/StartupHandlerImpl.cpp(327)] [startup-handler] [OnAuthenticationFailed] - Calling startupHandlerCallback.OnSystemLoginFailed
2016-09-15 12:51:04,057 INFO [0xf775eb4c] [src/services/impl/LifeCycleImpl.cpp(791)] [Life-Cycle-Logger] [OnSystemLoginFailed] - OnSystemLoginFailed - Callback received
2016-09-15 12:51:04,057 INFO [0xf775eb4c] [rc/services/impl/LifeCycleImpl.cpp(1353)] [Life-Cycle-Logger] [updateState] - Changing lifecycle State to: SIGNEDOUT
2016-09-15 12:51:04,057 INFO [0xf775eb4c] [(0) ] [JABBER.LIFECYCLE] [OnStateChanged] - state = SIGNEDOUT
2016-09-15 12:51:04,058 INFO [0xf775eb4c] [ignOnAuthenticationInfoStoreImpl.cpp(36)] [service-discovery] [getSSOEnabledServiceById] - SSOEnabledService not found for Auth Id: 2100. Returning NULL SSOAuthenticationInfo Smart Pointer.
2016-09-15 12:51:04,058 WARN [0xf775eb4c] [rvices/impl/system/SingleSignOn.cpp(138)] [Single-Sign-On-Logger] [isAuthenticatorSSOEnabled] - SSO Discovery disabled for 2100
2016-09-15 12:51:04,059 INFO [0xf775eb4c] [src/services/impl/LifeCycleImpl.cpp(805)] [Life-Cycle-Logger] [OnSystemLoginFailed] - OnSystemLoginFailed - Service is not SSO Enabled
2016-09-15 12:51:04,059 INFO [0xf775eb4c] [rc/services/impl/LifeCycleImpl.cpp(1155)] [Life-Cycle-Logger] [copyAndReleaseLifeCycleCallback] - Lifecyleimpl's unsupportedAuthenticatorCallback is reset, and its' lifeCycleCallback is reset.
2016-09-15 12:51:04,059 INFO [0xf775eb4c] [(0) ] [JABBER.LIFECYCLE] [OnCredentialsRequired] - with error code
2016-09-15 12:51:04,060 INFO [0xf775eb4c] [d(0) ] [JABBER.LIFECYCLE] [setSSOAccount] - is sso ? = false
2016-09-15 12:51:04,061 INFO [0xf775eb4c] [(0) ] [JABBER.LIFECYCLE] [handleSignInRequired] - authID = 2100 , isSSO = false
2016-09-15 12:51:04,062 WARN [0xf775eb4c] [d(0) ] [JABBER.LIFECYCLE] [handleLoginFail] - authID = 2100 , error
2016-09-15 12:51:04,063 INFO [0xdabbe930] [ents/jcfcoreutils/src/FileUtils.cpp(482)] [jcfcoreutils.fileutils] [createDirectory] - Creating directory: /data/user/0/com.cisco.im/files/Cisco/Unified Communications/Jabber/CSF/Telemetry
2016-09-15 12:51:04,064 INFO [0xf775eb4c] [ts/jcfcoreutils/src/ScopedTimer.cpp(166)] [scoped-timer] [pop] -
Thanks in advance
Sam
11 Replies 11
zdesignstudio
Level 4
Level 4
Do you have the debugs from the Expressway devices?
Please rate useful posts and mark answers as correct if applicable.
Thanks for the suggestion, after collected the debug from EXP-C and EXP-E.
It seems there is no traffic between EXP-E and firewall
Maybe I need to check with firewall team to verify that on coming Monday, because coming few days are public holiday here.
And update the result after 3 days
Thank you~
Did you ever get this fixed?
still not yet fix ...
Hi samhopealpha, some situation an some problem here with X8.9.1.
Finally, the firewall team has fixed the connection between EXP-E and firewall.
After collected the log on EXP-E and EXP-C (attached in this thread), I found 2 things
1.
In pcap (between EXP-E and firewall), it has TCP retransmission on port 8443
2.
In EXP-E, there is 401 unauthorized. (but the CUCM traversal Zone between EXP-E and EXP-C is ACTIVE)
2016-09-16T21:16:36.345+08:00 vcs tvcs: UTCTime="2016-09-16 13:16:36,345" Module="network.sip" Level="DEBUG": Action="Sent" Local-ip="10.10.242.18" Local-port="7001" Dst-ip="10.10.242.17" Dst-port="25035" Msg-Hash="14457791731929824121"
SIPMSG:
|SIP/2.0 401 Unauthorised
Via: SIP/2.0/TLS 10.10.242.17:5061;branch=z9hG4bK6efafce64075a5984134c1d4a764b99815492;received=10.10.242.17;rport=25035
Call-ID: 9e61f8356f136695@10.10.242.17
CSeq: 53382 OPTIONS
To: <sip:10.10.242.18:7001>;tag=48b21cf02f7ba61b
Server: TANDBERG/4133 (X8.8.1)
WWW-Authenticate: Digest realm="CUCM-Traveral-Zone", nonce="254502639a561f5576ad2213066df962dca56380b420fa4747d549c47352", opaque="AQAAAGPlxmXHSYAqvTOFWMfPSBYlLOpT", stale=FALSE, algorithm=MD5, qop="auth"
Content-Length: 0
But I have no idea these 2 issues are related to sign-in fail.
or there is anything I missed in the log ?
Thank you
Sam
Accroding to the pcap, on the eth1 (that is the interface of EXP-E connected to firewall)
I have the following assumption,
#1
EXP-E eth1 recevied a packet
o source: jabber mobile client (118.141.72.189)
o destination: EXP-E eth1 (192.168.243.18)
o Port: 8443
o Packet: SYN
#2
but, it seems EXP-E eth1 does not reply an SYN+ACK packet back to jabber mobile client
#3
then, EXP-E eth1 received "TCP re-transmission" SYN for 3 times.
The EXP-E eth1 still not reply any SYN+ACK packet back to jabber mobile client
It seems the jabber mobile cilent tried the process #1 - #3 for 3 times, then finally give up the sign-in process.
If my assumption is correct, it looks like there is someting stuck in EXP-E?
Anybody know what I have done incorrectly? or which part should I need to check ?
Thanks in advance
Sam
Anybody can help?
Attached with jabber.log file, but no idea how to interpret
Thanks in advance
Sam
Diego Chvz
Hi samhopealpha,
Did you already make sure that all necessary ports in the firewall are open? If possible, as a test you can set a any to any firewall rule and then do some login tests.
Don't forget to rate all useful posts.
samhopealpha
Level 2
Level 2
Anybody can help?
Hi.
Did you solve that issue? I've got the same situation.
Stuck here =(
