Expressway-E fails to locate CMR-Cloud using SIP
Expressway-C/E pair version X8.5.2 cannot locate CMR-Cloud using SIP protocol but correctly locates it via H.323.
Anyways, call goes through in SIP.
Anyone with same issue?
Thanks.
Filippo
Manish Gogna
Hi Filippo,
Make sure that the port range for Cisco Expressway-E, Cisco VCS Expressway, or other edge traversal devices and firewalls allows the following:
>> Inbound SIP signaling traffic from the WebEx cloud over TCP for ports 5060 and 5061
>> outbound SIP signaling traffic to the WebEx cloud over TCP for the ports 5060 – 5070
Try reducing the SIP TCP timeout as explined in the following guide ( pages 11-12 )
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/solutions/cmrcloud/CMRCloudEnterpriseDeployment.pdf
Manish
- Do rate helpful posts -
