Expressway-E - Only showing LAN1
Hello everyone,
I am setting up an Expressway-E, after loading the Advanced Networking option key and restarting the device, it is still only showing LAN1 in both IP configuration and in the ethernet settings.
Any ideas?
Joe Vallender
Level 3
Level 3
From a VCS Admin Guide:
To enable the use of dual network interfaces:
1. Ensure that the Advanced Networking option key is installed on the VCS Expressway.
2. Set Use dual network interfaces to Yes.
3. Set External LAN interface to LAN2.
You should configure the LAN 1 port and restart the VCS before configuring the LAN 2 port.
The LAN 1 and LAN 2 interfaces must be on different, non-overlapping subnets.
Joe Vallender
Level 3
Level 3
Ah yes, setting the use dual network interfaces to YES would probably help!
Thank you.
"Use dual network interfaces" should be on Ethernet Menu, not on IP menu, btw.
System-> Network Interface -> Ethernet
not System-> Network Interface -> IP
Or just a single menu for all.
Some of us are still very OSI oriented.
