Expressway-E Upgrade 8.9.2 gets in stuck
Ali Amir
I have 2 Expressway-C and 2 Expressway-E.  I could upgrad both Expressway-C and one of Expressway-E successfully but one of Expressway-E (master) gets in stuck after reboote. The follwing message are shown:
video1 login: Starting xmlapiadapter
Starting tandherg
Upgrade in process. Not starting crl_updater
Start ing vMtoolsd
Starting Migrate
<131>Jan 25 13:10:20 ttupgrade: UTCTime="2018-01-25-12:10:20" Event="upgrade" Detail="Running 10-Migrate"
<131>Jan 25 13:10:21 ttupgrade: UTCTime="2018-01-25-12:10:21" Event="upgrade" Detail="Running 20-cdbtransforms-precuil.py"
<131>Jan 25 13:10:21 ttupgrade: UTCTime="2018-01-25-12:10:21" Event="upgrade" Detail="Running 50-cdbtransforms.py"
<131>Jan 25 13:10:21 ttupgrade: UTCTime="2018-01-25-12:10:21" Event="upgrade" Detail="Running 50-tandberg-update.php"
The old version was 8.9.1.
Could I have you advice.
Ali Amir
The problem was solved after waiting for ca. 60 minutes. I suppose I was facing the same bug CSCuz94043.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuz94043/?referring_site=bugquickviewredir
Ali Amir
 Hi all,
We having same issue upgrading expressway-C and expressway-E.
Can you explain how to solve this?
Same issue during the upgrade from X8.11.4 to the version X12.5.1,
I have to wait ?? ^^
Hi @MBO46,
I hope your issue has been solved. But if not, I suggest you to waite.
Ali
