Expressway Registration Error - Received from unauthenticated source"
stephan_frye
Attempting to register a Tandberg 3000MXP (running F4.0 NTSC) to our Expressway, which is running X8.11.4 using H323. Getting the following error on the Expressway - "Received from unauthenticated source".  The Tandberg unit registers fine to our VCSc, running x8.8.3.
Looks like authentication is required, which we've configured, however, same error.
Is this old Tandberg system supported on the Expressway?  Thoughts?
-Stephan
Thanks Wayne!  Agreed regarding replacing. This is the first step in that process, as the Tandberg is currently registered to very old VCSc\VCSe that goes EoS 9-30-2019.
I was able to get the Tandberg to successfully register to the Expressway after creating the necessary Zone and Subzone and associated membership rules.
Many thanks!
It could be because you're only running F4.0 on the old MXP - that's very old software.  The most recent software release for a 3000 is F9.3.4 (dated Feb 2016).  F4.0 is really ancient from back in 2005 from memory.
The 3000 MXP went end of support in 2017, so I'd highly recommend that you consider replacing it with something a bit more modern and supportable.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Many thanks!
