factory reset on c60
aniefiok essien
hello guys pls is anyone there that can help me with this issue?
a client of mine forgot the password they had used on their C60
codec and that has affected the most administration actions like
IP change and other things, though i can access the kit via console
but cannot not do a factory reset on the kit.
pls
amehla
Hi Aniefiok,
try below steps:>
  • Connect a serial cable to the system at 38400, 8, N, 1
  • Reboot the system
  • Log in with the user "factoryreset". This user is only available a short period of time after reboot (in TC6 it is always available). When logging in with this user it is possible to do an xcommand systemunit FactoryReset Confirm: Yes.
  • Do a reboot: "Xcom boot"
  • The system is now factory reset.
7 Replies 7
amehla
Hi Aniefiok,
try below steps:>
  • Reboot the system
thanks Aniefiok,
After short rebooting you must login to the c60 unit by putting user : admin and password : "" (blank)
I have a serial connection to the C60, however, after reboot all I see is a bunch of encryption-gibberish code/text. Did I miss a step or is there something else I need to do?
i realized that i did not set the COM settings to the 38400, afterwards, its working fine now.
Using the serial interface:
You have to connect to the video system’s COM port with a serial cable.
The serial port is enabled as a default, but it may have been disabled.
The connection parameters for the COM port are as follows:
• Baud rate: The default value is 38400 bps, but it may have been changed
• Data bits: 8
• Parity: None
• Stop bits: 1
• Flow control: None
Connect serial 1:1 cable to your laptop & Codec
Open Putty make the right serial settings (Baud rate 34800) and open the terminal program
(Check the serial port number at your laptop hardware settings)
Turn the codec ON, if the serial connection is correct you will see bootup information
Wait until the codec is finised booting, when the login promt is active,
Use: factoryreset
login:
login: factoryreset
Last login: Sun Jun 15 10:42:46 on ttyS0
Do you really want to perform a factory reset? [y/N] y
Chose: y
Performing a factory reset!
Flash device: /dev/mtd0
Image: /mnt/base/active/bootsw
Offset: 0x00300000
Max size: 0x00100000
Retry 1 times if failing
File length 0x000a4980 (674176)
Image is up to date, exiting
Erase block: 0x002f0000
Erase NOR flash block 0x002f0000 (65536/0x10000 bytes)
Image: /mnt/base/active/pkgextract.elf
Offset: 0x00100000
File length 0x0001f6e9 (128745)
Factory reset: OK
login:
Reboot the codec (Off & On), the codec is now, in factory default state.
Hi Aniefiok,
Similar questions have been asked before, a quick search of the forums will give you plenty of results.
You can try the default admin passwords first in case it is one of them, either leave the password blank, or try TANDBERG (all caps).
Failing that, the factory reset procedure, as indicated by Amit, or in any of the other forum threads linked above, should help you.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Follow the steps given by Aniefiok and then login to c60 unit by putting user : admin and password : "" (blank).
Cheers
Janu Sandaruwan Maha Godage
janumg@gmail.com
