GW CDR on TMS
epicolo
Level 3
Level 3
Hi all
Does anyone know if TMS 13.1.x can collect or receive ISDN GW 3241 (v2.1) CDR logs ?
There is a tab in TMS (in the system, Logs > Call Log), but it is always empty.
PS: The GW is added as a system in TMS, with SNMP. In this environment, they don´t use TMS to schedule the calls.
Kjetil Ree
It is a known bug (CSCts33831), and a fix will be released in Cisco TMS 13.1.2.
You can get TMS 13.1 to pick up ISDN GW CDRs by running the following SQL query against your TMSng database:
      INSERT INTO objSystemCDRProcessStatus (SystemId, LastUpdated, LastAttempt, LastEventReceived)
                  SELECT Id,'1900-01-01T00:00:00Z','1900-01-01T00:00:00Z', GETDATE() from objSystem
                  where objSystemType_Id = 41
                  AND Id in (select Codec_Id from objFolder_System)
                  AND Id NOT IN (select SystemId from objSystemCDRProcessStatus)
You'll only have to run the query once, unless you later add a new GW to your TMS.
Kjetil Ree
OK, thanks. Now it works.
