H.323 Failed to Connect to xxx.xxx.xx.xxx 56001: Authentication failed
RobPendleton
My customer has this VC control on x4.3 and their VCS on x4.3 sw level.
The VC Control is getting this warning in Red above. Can anyone help on this or suggest anything ?
This is the Transversal server Zone between the VC Control and the VCS Expressway
This below is a screenshot of the Expressway.
States -Warning Systems unreachable
Authentication is turned off.
awinter2
Level 7
Level 7
Hi Rob,
my first thought would be to check that both VCS's involved have a working NTP server (Preferably the same, public NTP) so that their time is synchronized.
Andreas
12 Replies 12
awinter2
Level 7
Level 7
Hi Rob,
Andreas
Thanks Andreas , I will check this out.
Your'e  "The Man" ,  That has fixed the issue.
Thanks Heaps Andreas
Rob
Happy to help Rob.
Andreas
HI,
I have a VS expressway that is getting a failed error when inputing a public or private NTP server. I can access both NTP servers from the control.
The customer says traffic is allowed from the DMZ to Internet.
Any ideas?
Randall
So you can access the same ntp server from both control and expressway
Rob
Mobile - 021 978 129
Sent from my iPhone
No. I cannot access any ntp server from the expressway. I can from the control
Randall
Sent with Good (www.good.com)
You should be able to access the ntp server. Is it a public ntp
Rob
Sent from my iPhone
Yes
Fw is an ASA
Sounds like the fw is stopping it. Is there a proxy being used
Rob
Sent from my iPhone
Thanks Rob. That is what I was thinking
Randall
