HD call from EX90 to C20
amrishmehta
I have registered telepresence EX90 and C20 with CUCM 8.6 over SIP protocol and I can make video call to each other successfully.
The issue is all calls are automatically connected on 384 kbps 640 resolution even after selecting call rate 6MB.
5 Replies 5
crisalex
Kindly asked to check :
On EX 90  / C20
1. default call rate
2. max incoming bandwidth
3. max outgoing bandwidth
Do you have on CUCM any bandwidth limitation set ?
Can you take a log from the C20 / Ex 60 while reproducing the issue ?
In order to take the logs :
IP issue (SIP)
Commands in bold
Open the console/telnet/ssh session with codec
Reboot codec by
xCommand boot
Reopen the console/telnet/ssh session with codec
xstatus
xconfig
log ctx SipPacket debug 9
Make a call and keep running until you have recreated the problem
Hang up call
log ctx SipPacket debug off
Once recreated the problem and captured the log, reboot codec by
xCommand boot
Access to codec WebGUI for download log file, http://
Download the latest file “log.tar.gz”
t.svatek
Level 3
Level 3
Hi Amrish,
on CUCM: check Regions
on VCS: check Default call bandwidth (VCS configuration -> Bandwidth -> Configuration)
Tino
Thanks for reply,  I am not using VCS, endpoints are directly registered with CUCM.
Amrish
Hi Amrish,
May be in these case you need to check CUCM configuration, whether there is any bandwidth limitation.
I think if we can check SIP log, may be we can narrow down issue, could you please follow steps provided in first respond.
Vivek
Dear all,
Thank you for your help, the issue has been resolved after changing the CUCM region config.
