11-22-2015 11:47 PM - edited 03-18-2019 05:14 AM
i have a problem in my voip to pstn calls
it sounds like a hiccup in voice
by searching in cisco forums, it seems to be a choppy voice problem, but none of sulotions was successful
i have tried vad, palyout mechanism, and some other sulotions
can anyone help me please?
here is my different config shows
11-23-2015 01:05 AM
You can configure a triggered PCM capture as explained in the following link to identify where the voice quality issue is originating from
http://www.cisco.com/c/en/us/support/docs/voice/h323/116078-technologies-technote-commandreference-00.html#anc13
You can decode the output on http://pcet.cisco.com/ as explained in the following video
https://www.youtube.com/watch?v=B_8CIKamSsc
You can open a TAC case with the above output and the information already collected by you to get a speedy resolution.
Manish
- Do rate helpful posts -
