06-07-2013 12:44 AM - edited 03-18-2019 01:14 AM
I am configuring a C40 codec running 6.1 software.
I want to restrict the systems that can access to codec via SSH/HTTP etc. and have found the RemoteAccess Allow under Configuration > System Configuration > Network
I want to enter a range of addresses (192.168.2.1 to 192.168.2.254) but cannot work out the syntax to do this. The admin guide and API reference mention that ranges are supported but only give examples for specific hosts.
Can anyone help?
Solved! Go to Solution.
06-07-2013 02:28 AM
I think the command affects the iptables on the codec which is a linux based system.
For the range 192.168.2.1 to 192.168.2.254 you probably need to specify the following :
xConfiguration Network 1 RemoteAccess Allow: "192.168.2.0/24".
I tried this on my system :
xConfiguration Network 1 RemoteAccess Allow: "144.254.10.0/24"
Then the iptables show following entry :
[dderidde-ex90-home:/var/log/eventlog] $ iptables --list -n
Chain INPUT (policy ACCEPT)
target prot opt source destination
Chain admin (1 references)
ACCEPT all -- 144.254.10.0/24 0.0.0.0/0
DROP all -- 0.0.0.0/0 0.0.0.0/0
That should do the trick I think.
Danny.
06-07-2013 02:28 AM
Danny.
06-07-2013 06:24 AM
Thanks Danny,
Worked fine
