How to Factory reset EX90 whose version is TC4.1.2.257695
xuekai zhang
Saurabh Gupta
Level 3
Level 3
Hi Zhang,
You can factory reset the Ex90 in a couple of ways :-
First way
  • Open the console/ssh session with codec and login as “root” user
  • rm /mnt/base/active/config.db, this remove the current configuration file from Codec
  • reboot
Second Way
  • Open the console/ssh session with codec and login as “admin” user
  • xCommandsystemunitFactoryReset Confirm: Yes
Third Way
If EX-series Endpoint is not accessible or rebooting use power switch for factory default
  • Unplug power cable
  • Re plug power cable
  • Immediately when the green led in the bottom left corner of the EX90 lights up, press and hold the power button for 10 seconds (the led will turn off), until the green led lights up again.
  • Push the power button twice within two seconds (two short pushes)
Hope it Helps.
Saurabh
Saurabh Gupta
Level 3
Level 3
Hi Zhang,
First way
  • reboot
Second Way
Third Way
Hope it Helps.
Saurabh
Thanks.Issue solved.
I use xCommandsystemunitFactoryReset Confirm: Yes to reset
About third way, I can't find any green led.It's white led.
Fred Spikker
All,
Please be aware that the procedure in this post does not apply to systems with version TC5.1! There is a great video on how to perform a factory reset for 5.1 at: https://supportforums.cisco.com/videos/4440
