Bookmark
Subscribe
4870
How to get TMS Release Key ?
baguscandra
I received 2 papers that consist of LIC-TMS-APL-S80100 and  LIC-TMS-PMP-PAK. After installing TMS it needs to enter the Release Key. How to get TMS Release Key ?
I cannot find from all of my papers. I only see the Activation Code from LIC-TMS-APL-S80100 paper.
Thank you.
You need to register the PAK for you to get the release key and license options for your TMS.
Use the Product License Registration Tool: (need your Cisco ID to use this tool)
https://tools.cisco.com/SWIFT/LicensingUI/Quickstart
1. Enter the PAK for your TMS and select Fulfill.
2. Click on the PAK/Token ID and select Get New Licenses. Assign the licenses to your TMS serial number. You should have the copy of the TMS serial number. The TMS serial number is the Activation Code that is on the LIC-TMS-APL-S80100 paper license.
3. After fulfilling, you will received an email from Cisco licensing for the Release Key of your TMS with the option keys.
If you find hard getting the licenses, you can email Cisco licensing directly - licensing@cisco.com.
regards,
Acevirgil
***Please rate or mark as correct answer if this post is helpful.
Hi Acevirgil,
I got the option key but not the release key. Anyway, I will directly email to licensing@cisco.com.
Thank you.
well what Acevirgil de Ocampo wrote was correct for getting the option keys.
but for getting the release key there is a option in the license tool: under "Get Other Licenses" there is a option called "Telepresence Software Release Key", use this one, enter the "Activation Key" from the License Paper into the Serial Number field and proceed.
