How to shut down a VCS from the command line?
Is there any command that can turn off a VCS?
Type xCommand reboot?
Regards...
Aman Soi
I think you cannot shutdown VCS from CLI. For that , u need to do through GUI under Maintenance --Shutdown
from CLI, u can run command xcommand  restart for restart
regds,
aman
7 Replies 7
Aman Soi
regds,
aman
Aman is correct, there is no CLI command to shutdown the VCS, the only method is using the web interface.  Looking through the admin guides, in VCS releases X7.2 and earlier, this was mentioned as not being possible, however starting with X8 and later that text was removed for some reason.
If you telnet or ssh to the VCS and log in as the "root" user, then you can use the shutdown command.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Wayne is right!   Use this after ssh with root user:
shutdown -t secs: now
That doesn't shut it down. It only puts it in "Maintenance Mode"
# shutdown -t secs: now
The system is going down to maintenance mode NOW!
abdul ilyas
login as root and use
"shutdown -h -t secs: now".
Note: I did it just last night, ver x8.6.
Enter with root account by ssh and type shutdown -h now
