11-07-2019 05:12 AM
Hi, looking for a little assistance. I am unable to upgrade from ce9.4.2 --> ce9.6.4. The system only gives me an error of installation failed. Initially tried from TC7.6.3 -- ce9.6.4 but that failed, so tried 9.4.2 and that was successful.
Cisco TelePresence SX20
Solved! Go to Solution.
11-07-2019 08:28 AM
Here's my take - all these "steps" in between minor releases is unnecessary - I've gone from CE8.3.1 to 9.8.1 without any steps in between.
My guess - you have downloaded the wrong file for 9.6.4. There are two that you'll find on the site that say SX20, 9.6.4, but they are not the same, the crypto and non crypto versions.
Assuming you have standard crypto capable SX20, this is what you need:
s52010ce9_6_4-ce8365c8325.pkg
My guess is, you have this:
s52011cenc9_6_4-ce8365c8325.pkg
Note the "nc" in between the ce and the 9_6_4. That will not work - I think it gives some silly error about release keys or something.
That said - I'd probably jump to CE9.9, that is the latest version and fixes a lot of bugs. That file name is:
s52010ce9_9_0-46f7ea38fda.pkg
11-07-2019 05:53 AM
11-07-2019 05:56 AM
11-07-2019 06:11 AM
Yes
11-07-2019 06:13 AM
11-07-2019 06:49 AM
11-07-2019 07:00 AM
11-07-2019 08:16 AM
Are you using correct file for SX20 to upgrade to CE9.6.4. Each SX series endpoint has different software file. For SX20, the correct file is s52010ce9_6_4-ce8365c8325.pkg.
Also, I would recommend to upgrade SX20 to CE9.8.0 (s52010ce9_8_0-be9359915d0.pkg) as this is the current recommended version.
11-07-2019 08:52 AM
11-07-2019 06:24 AM
11-07-2019 08:28 AM
11-07-2019 08:44 AM
11-07-2019 09:16 AM
The s52040 file would have been for DX70/80.
11-07-2019 09:37 AM
Thanks for the info really appreciated. Not all heroes wear capes!
