Integration of Tandberg VCS with CUCM
ayokunles
I wanted to ask a few questions with respect to the above.
We currently have a tandberg VCS installed and we want to integrate it with our current CUCM.
I wanted to know if I can use the existing Voice Gateway Router for the Video calls and whether I can use the same E1 line for voice for video?
thanks
Dennis Mink
What is it you are trying to achieve with the integration?
(dont use E1 channel bundeling for video; its ancient, go IP!)
Please remember to rate useful posts, by clicking on the stars below.
The primary aim is to make video conference calls outside the organization
the secondary aim is to make voice calls to other IP Phones in the organization.
I wanted to know if I can use the same E1 provided for voice for video
would be grateful if answered.
shkn
Here it seems you are trying to use the existing router (voice gateway) as for ISDN termination and the existing E1 PRI /E1 R2 for carrying Video traffic.
In this case the PRI will be able to support the video , but you would have to check if  Cisco Integrated Services Router which supports Video services is  to be  used for  PRI termination.
Shyam
