01-17-2017 08:53 AM - edited 03-18-2019 06:47 AM
found an old post but nothing is working
I can not find the test IP address for the video conferencing system.
all Tandberg IP address is no longer functional
seeking a two way video and audio and callback for MXP telepresence Tandberg
Solved! Go to Solution.
01-17-2017 02:00 PM
VTCTest is a great site that Gary Miyakawa set up for testing, as discussed in VTCTalk forum at http://vtctalk.com/forum/showthread.php?t=39971. It is the 71.14 addresses referenced by Patrick above.
01-17-2017 09:23 AM
Appears the Cisco test systems are down, but you can try the non-Cisco systems listed here: Loopback Testing for TelePresence. Note, I haven't tested them myself.
01-17-2017 10:30 AM
thanks for the fast response but i am seeking a working response !
the link provided by you says at the top 2 years old post.
"12-15-16 - Services are currently down to to internal infrastructure reorganization. We are working to reactive these services soon."
what is the point of answering a post without knowing !!!
you should just erase your answer, no help to anyone, no points for you
01-17-2017 10:30 AM
I've used them times, some recently, regardless of the post being 2 years old. Did you try any of them?
Regarding the Cisco test sites (loopback@cisco.com, loopback@rtp.ciscotac.net, etc), it appears they do work, Mathew must have not updated his post yet to reflect this.
The IPs 71.14.2.157 and 71.14.2.158 under "Other (non Cisco)" test sites do work, however 71.14.2.154 appears to not be working.
01-17-2017 02:00 PM
01-17-2017 08:43 PM
I found these working test sites, as of January 17th 2017.
VC sites working with Tandberg
1- callback and test video, audio and duo (limited trial)
ip ; 71.14.2.158
2- static video locker room with audio room tone
ip ; 140.242.250.203
