IP Communicator with VT Adv 2.0
rdamaso
I have installed VTA 2.0 in a machine with IPC 2.0.
The VTA recognizes the camera but not the IPC.
What?s is the problem?
Do I need to do something?
6 Replies 6
noelger
(1) Make sure that VTA is looking for CDP packets from IPC and not from an ethernet-attached hard phone (there is a graphic where you can connect the line from the camera to IPC or a hard phone)
(2) Make sure you do not have a firewall that could be gobbling up the packets.
Hi, Kenneth.
I found out a documentation saying that the minumal version to implement this is 4.1(3)SR1. My version was 4.1(3). I did the upgrade and the solution worked fine.
Thanks.
hi Rodrigo,
I have problems with the configuration between VT Advantage and Ip Communicator.
The camera not recognized the ipcommunicator.
Can you help me?
try to confirm that Video Capability is enable in CallManager configuration for the IP Communicator.
I am using IP Communicator with VT Advantage, 2.0 without any problem.
I search this option in the CCM but not find it on the IPC only can view this option for IP Phones.
I have the CCM 4.0(2a)sr1a. This version support VT Advantage 2.0 with IPC???
Per VT Advantage 2.0 release notes at http://www.cisco.com/en/US/products/sw/voicesw/ps5662/prod_release_note09186a00806cbe7d.html , VT advantage 2.0 requires at least CallManager Version 4.1(3), Service Release 1 to work with Cisco IP Communicator.
If this answers your question, please rate this response.
Neal
