ISDN Gateway – How to set static Jitter Buffer
Is it possible to set a static Jitter Buffer on an ISDN GW MSE 8321 and a C-Series codec? And IF so how do you do it?
Martin Koch
Unless that there is a undocumented parameter, not thats not possible.
The only thing I saw mentioned in the datasheet (not even the documentation) was thedynamic jitter buffer.
http://www.cisco.com/en/US/prod/collateral/ps7060/ps11305/ps11317/ps11340/data_sheet_c78-626477_ps11448_Products_Data_Sheet.html
But there also seem to be no parameters for that.
