ā03-01-2014 12:00 PM - edited ā03-18-2019 02:40 AM
How can I escalate to a multipoint call using Jabber 4.7 and variuos endpoints on my internal network.Thanks for all your help.
Here's my current set-up
-- Cisco MCU 4501
- sip enabled
- registered to TMS
-- VCS-c
-- TMS
-- Jabber 4.7 for PC Users
-- Polycom HDX's
-- Cisco C20's
P-to-P Jabber 4.7 is working fine.
ā03-01-2014 01:34 PM
You could use Multiway, as you don't say which software version the VCS-C is running, choose the relevant Multiway Deployment Guide from here:
/jens
Please rate replies and mark question(s) as "answered" if applicable.
ā03-02-2014 08:22 AM
Yes, there are different guides mentioning different versions, but the core element is here more
that a VCS is used without the conductor.
The feature "Multiway" is a combination of different features. Its settings on the MCU, VCS and the provisioning,
as well it needs to be supported by the endpoint initiating the join (JV4.7 is ok) as well as the endpoint getting
joined. So you also want to check on their software version, especially regards 3rd party devices like your HDXs.
Please remember to rate helpful responses and identify helpful or correct answers.
ā03-03-2014 02:31 PM
This is where am at at this point. I can booked conference over TMS (SVer14.3.1) adding Cisco MCU 4501 (SV4.3) VCS (SV 7.2.2)
Call will initiate to MCU and C20's "status Connected on MCU" but Jabber (4.7) will fail ?
Log Event VCS :
TVCS: Event= "Call Rejected" Service="SIP" Src-ip="111.111.111.111" Src-port="61654" etc etc etc ...
Hoping I can get this resolve with you guys help ... Thanks .
ā03-03-2014 03:40 PM
Check out the deployment guide. There are some pre-req on TMS, VCS and MCU which have
to be matched to get it working.
Just as a short summary. the VCS will generate a unique ID for each new request. (see conference factory
conf on the VCS) this alias has to be reachable and auto created on the MCU (port reservation off,
auto generation of conferences on). The conference factory and the auto generated aliases have
to be properly routed then it should work. But like Jens said, check the guide.
ā03-03-2014 02:32 PM
please read-on ! thanks all for the assistance !!
