License Cisco Webex Room Kit
FERTHOFELES
Hi!
If I buy a CS-KIT-K9 how can I license it on a CMS? Also, how will it be on a CUCM v11? Please, I do know that LIC-TP-11X-ROOM is end of life and it replacement is Cisco Cisco Meeting Server, and that the licenses are as same tat CUCM with UWL or directly uses the PMP licenses attached to the servers.
Thanks in advanced.
Best Regards.
2 Accepted Solutions
Wayne DeNardi
You would register the Room Kit endpoint to your CUCM, the same as any other Video endpoint, and it will use the same licences as any of the other endpoints would (C Series, MX Series, SX Series, etc).  You will need to make sure that your CUCM device pack is up to date (see Device Pack Compatibility Matrix)
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Hi ,
you need telepresence room license to register with call manager for CS-KIT-K9 (Cisco Webex Room Kit).
Shalid
Please remember to rate helpful responses
6 Replies 6
Wayne DeNardi
Wayne
Sorry, which license should I use to register C Series, MX Series, SX Series, etc?
Hi ,
Shalid
Hi shalid,
is it possible for you to guide how license is applied and how devices see each other? any document on flow of whole setup?
i have setup room-kit at locations. with license purchased and activated, do both systems starts with each other automatically?
please share your thoughts.
As your question is off topic to the OP it is advisable for you to create your own post asking your question. Besides that this post is marked as solved and multiple years old, so it not recommended to ask question on it.
Response Signature
Thanks a lot!
