01-10-2017 06:28 AM - edited 03-18-2019 06:46 AM
Hello everyone
I have CSF devices and a sx10 registered to the CUCM. Can I make a video Call from Jabber to sx10? AS far as I tried I cn make Audio Calls but not Video as video is not displayed.
What do I need in order to make video calls?
Thank You
Solved! Go to Solution.
01-10-2017 11:04 PM
Hi Juljan,
yes, you can make a video call between them, a few things to check:
Media Termination Point Required box should be unchecked on SX10 config page
Check that sufficient bandwidth is allocated between these two devices
Also, make a test between two Jabber devices and two SX10's separately if possible , it will help to determine if the device level settings for video are enabled correctly
Manish
01-10-2017 11:04 PM
Hi Juljan,
Manish
01-11-2017 01:20 AM
Hi Manish
Media Termination Point Required box should be unchecked on SX10 config page did the trick.
Thank You
01-11-2017 01:21 AM
Good to know that, thanks for updating the post with resolution.
manish
