Make a Call from Jabber to Telepresence sx10
Juljan Plaku
Hello everyone
I have CSF devices and a sx10 registered to the CUCM. Can I make a video Call from Jabber to sx10? AS far as I tried I cn make Audio Calls but not Video as video is not displayed.
What do I need in order to make video calls?
Thank You
Manish Gogna
Hi Juljan,
yes, you can make a video call between them, a few things to check:
Media Termination Point Required box should be unchecked on SX10 config page
Check that sufficient bandwidth is allocated between these two devices
Also, make a test between two Jabber devices and two SX10's separately if possible , it will help to determine if the device level settings for video are enabled correctly
Manish
Manish Gogna
Hi Juljan,
Manish
Hi Manish
Media Termination Point Required box should be unchecked on SX10 config page did the trick.
Thank You
Good to know that, thanks for updating the post with resolution.
manish
