Hi All,
Does anyone has already try to create several autoattendant and put restriction for avoid move from one to another even if you use ID of the auto-attendant.
One of my customer has two autoattendants and I would like avoid from one access to the other. I know that you can direclty from GUI create link or not between autoattendant but even if you don't have this link you can access if you put the numeric ID.
I've tried on the VCS to make CPL for avoid call between auto-attendant but it doesn't work because the MCU doesn't ask the GK when you use numeric ID.
