MXP Edge 95 to HDMI TV ?
habouzyad
I have an MXP Edge 95 , and I want know  the foloowing information :
1- Can I connect this codec to TV that have an HDMI input?
2- What kind of cables are shipped with this codec?
Thanks in advance
Hicham
deamanga
Hi Hicham,
The MXP Edge 95 got a DVI video output which suppot (XGA)HD720P.
Yes you can connected this output  to a TV by using DVI/HDMI cable which is not provided in the original boxe.
Dean.
Valentin Ichim
A DVI to DVI cable and a DVI- HDMI adapter are included in the box. We tested this connection and it is OK but you have to pay attention to the physical connection of the adapter to TV.
