08-14-2012 12:37 PM - edited 03-17-2019 11:36 PM
Hi All,
I've trying to make outbound video calls to test sites and other 3rd party video systems and I'm unable to get any outbound calls working.
Inbound calls work fine, no issues there at all.
I'm getting namely "NOT FOUND" or "Request Timeout" errors in the VCSE logs (I know the end points I'm trying to call are working as I can reach them with other 3rd party SIP products).
I'm going to see if there are any SIP/H323 "fixup" type settings on the firewall.
In addition, I do have a Dual Network option key installed, but its not cabled for the dual option (not certain this may be causing the issue or not), I don't need it so I'm not using it.
Its a basic config, single VCS control on the inside and single VCS Expressway on the outside (with Public IP Address) and only a single interface cabled. The outside interface is in the clear (no firewall in front of it).
Here's a couple examples of the logs taken from the VCSE
(this call was a movi user connected from the internet)
tvcs: Event="Call Rejected" Service="SIP" Src-ip="x.x.x.x" Src-port="53268" Src-alias-type="SIP" Src-alias="sip:user.movi@domain.com" Dst-alias-type="SIP" Dst-alias="sip:loopback.sip@cisco.com" Call-serial-number="d17985da-e644-11e1-b39b-0010f323814a" Tag="d17986c0-e644-11e1-a46f-0010f323814a" Detail="Not found" Protocol="TLS" Response-code="404" Level="1" UTCTime="2012-08-14 19:18:34,801"
and
This call was a dual profile 55 on the inside of the network making an outbound call to a user on the internet using the Cisco Jabber video software (movi, jabber.com)
Aug 14 14:50:50 | tvcs: Event="Call Rejected" Service="SIP" Src-ip="IP_of_VCS_Control" Src-port="25153" Src-alias-type="SIP" Src-alias="sip:5005@domain.com" Dst-alias-type="SIP" Dst-alias="sip:user@jabber.com" Call-serial-number="411dc2bc-e649-11e1-afaf-0010f323814a" Tag="41e14408-e649-11e1-9d51-0010f32305ae" Detail="Request Timeout" Protocol="TLS" Response-code="408" Level="1" UTCTime="2012-08-14 19:50:50,826" |
The IP Address of the VCS control is listed as the source IP (not sure this is normal or not).
Note: I removed names/ip addresses for security reasons.
Any ideas?
thanks,
Paul
08-14-2012 02:00 PM
Paul,
checking that inspection/fixup is disabled for SIP and H323 is always a good initial troubleshooting step.
As for the log entries you provided, the first entry shows a call to loopback.sip@cisco.com, and the response code for that call is 404 Not found, which could for example be caused by a lack of a DNS zone on your Expressway. A 404 response can in many cases be a completely legit and expected response.
The second log entry indicates that there seemingly isn't any NAT between your VCS Control and the Expressway, since the source address is shown as the actual IP address of the VCS Control (According to what you describe).
Can you confirm that your network routing allows the VCS-E to reach the subnet of the VCS-C through the default gateway that is configured on the VCS-E, and that traffic sent from the VCS-C to the VCS-E is actually being routed through the router which is acting as the default gateway for the VCS-E?
If not, then you might have an asymmetric routing problem which could explain the 408 Request timeout response which you are seeing in your logs. 408 Request timeout is a response which you normally shouldn't be seeing in a healthy network (Assuming the network configuration on your VCS's is correct).
- Andreas
06-14-2017 05:02 AM
Hi All,
Greetings !!
From SX20 telepresence unit, I am able to receive calls but cannot dial outside calls.
Please can anyone help in identifying the issue and resolve it
below are the logs and config for your reference or vcs c and e
Logs in VCS-C:
State | Connection Failed |
Start time | 2017-06-14 12:52:29 |
End time | 2017-06-14 12:53:27 |
Duration | 58 seconds |
Tag | 71343458-a756-45b5-a6ed-a2857c413c82 |
Serial number | 6565b4e0-d62d-4b0a-9447-9294bf2ac49c |
Type | Video |
SIP variant | Standards-based |
Bandwidth | |
Requested | 384 kbps |
Allocated | 384 kbps |
Route | CUCM Neighbor -> Zone001ToTraversalSZ -> TraversalSubZone -> Zone004ToTraversalSZ -> Traversal Zone |
Leg 1 | |
Bandwidth node | CUCM Neighbor |
Source alias 1 | sip:123@10.30.27.15 (Url) |
Target alias 1 | sip:709@kdcc.com (Url) |
Protocol | SIP |
Address | 10.30.27.15:5070 |
Transport | TCP |
Reason | Not found |
Cause | 404 |
Leg 2 | |
Bandwidth node | Traversal Zone |
Protocol | SIP |
Address | 10.30.27.19:7002 |
Transport | TLS |
Encryption type | None |
Leg 3 | |
Target alias 1 | 709@kdcc.com (H323Id) |
Protocol | H323 |
Address | 10.30.27.19:6001 |
Reason | Not registered |
Cause | Destination not found |
Session 1 | |
Status | Failed |
Media routed | True |
Call routed | True |
Participant 1 | Leg 1 |
Participant 2 | Leg 2 |
Bandwidth allocated | 384 kbps |
Bandwidth requested | 384 kbps |
Session 2 | |
Status | Failed |
Participant 2 | Leg 3 |
Priority | Rule name | Protocol | Source | Authentication required | Mode | Pattern type | Pattern string | Pattern behavior | On match | Target | SIP variant | Enabled | Actions |
1 | Route to CUCM | Any | Any | No | Alias pattern match | Regex | (.*)@gulfsls.com | Replace | Stop | CUCM Neighbor | Any | View/Edit | Clone | ||
2 | Local Zone - No domain | Any | Any | No | Alias pattern match | Prefix | (.+)@gulfsls.com.* | Replace | Continue | LocalZone | Any | View/Edit | Clone | ||
5 | LocalZoneMatch | Any | Any | No | Alias pattern match | Regex | (.+)@gulfsls.com.* | Leave | Continue | LocalZone | Any | View/Edit | Clone | ||
10 | Dial IP Address Search Rule | Any | Any | No | Any IP address | Stop | Traversal Zone | Any | View/Edit | Clone | |||||
45 | CEtcp-cucmadmin.gulfsls.com | SIP | Any | No | Alias pattern match | Prefix | cucmadmin.gulfsls.com;transport=TCP | Leave | Stop | CEtcp-cucmadmin.gulfsls.com | All SIP Variants | View | Clone | ||
50 | Route to CUCM Outside | Any | Any | No | Alias pattern match | Regex | ^(\d(8))@gulfsls.com(.*)$ | Leave | Stop | CUCM Neighbor | Any | View/Edit | Clone | ||
90 | External IP address search rule | Any | Any | No | Any IP address | Continue | Traversal Zone | Any | View/Edit | Clone | |||||
100 | Traversal zone search rule | Any | Any | No | Any alias | Continue | Traversal Zone | Any | View/Edit | Clone |
2 | Enabled | "Add domain where none exists" | ([^@]*) | Regex | Replace | \1@gulfsls.com | View/Edit | |
5 | Enabled | Convert unified CM supplied domain information to Expressway | (1\d{2})@vcse.gulfsls.com)(:.*)? | Regex | Replace | \1@gulfsls.com | View/Edit | |
13 | Enabled | Transform to strip domain from IP-address call | (.*)\.(.*)\.(.*)\.(.*)@h323.gulfsls.com | Regex | Replace | \1.\2.\3.\4 | View/Edit |
Logs in VCS-E:
End time | 2017-06-14 12:53:07 |
Duration | 38 seconds |
Serial number | 85679bc2-c38a-413a-a279-cf5a5a8cfe53 |
Type | Video |
Bandwidth | |
Route | Traversal Zone -> Zone003ToTraversalSZ -> TraversalSubZone -> Zone002ToTraversalSZ -> DNS Zone |
Leg 1 | |
Protocol | SIP |
Address | 10.30.27.18:25031 |
Transport | TLS |
Cause | 404 |
Leg 2 | |
Bandwidth node | DNS Zone |
Protocol | SIP |
Address | 62.215.248.172:5061 |
Transport | TLS |
Leg 3 | |
Protocol | SIP |
Address | 62.215.248.172:5060 |
Transport | TCP |
Leg 4 | |
Protocol | SIP |
Transport | UDP |
Leg 5 | |
Protocol | H323 |
Address | 62.215.248.172:1719 |
Reason | Undefined reason |
Cause | Request timeout |
Session 1 | |
Status | Failed |
Session 2 | |
Status | Failed |
Session 3 | |
Status | Failed |
Participant 2 | Leg 4 |
Session 4 | |
Status | Failed |
Participant 2 | Leg 5 |
Priority | Rule name | Protocol | Source | Authentication required | Mode | Pattern type | Pattern string | Pattern behavior | On match | Target | SIP variant | Enabled | Actions | |
50 | LocalZoneMatch | Any | Any | No | Any alias | Continue | LocalZone | Any | View/Edit | Clone | |||||
100 | Traversal Search Rule | Any | Any | No | Any alias | Continue | Traversal Zone | Any | View/Edit | Clone | |||||
150 | DNS Zone search rule | Any | All zones | No | Alias pattern match | Regex | (?!.*@gulfsls.com.*$).* | Leave | Continue | DNS Zone | Any | View/Edit | Clone |
Priority | State | Description | Pattern | Type | Behavior | Replace | Actions | |
1 | Enabled | Transform destination aliases to URI format | ([^@]*) | Regex | Replace | \1@gulfsls.com | View/Edit |
08-14-2012 02:06 PM
you can limit some generic mistakes by checking out:
Than would look into:
* do you have a dns zone
* do you have a search rule hitting that zone
* can you resolve dns from the vcs-e (see screenshot on how to test it)
under maintenance / tools you can also find the locate tool. Try that with loopback@cisco.com and copy paste the result here.
You should see a green True somewhere like:
If all this did not help,
08-14-2012 08:45 PM
Here's a failed call detail
151.124.146.111 = Real dual 55 profile IP on internal network
205.214.144.152 = VCSE Public IP Address
Call details
You are here:Status Calls Calls Call details
Call information | |
Start time | 2012-08-14 22:29:07 |
Tag | 5ed43ae4-e689-11e1-b15c-0010f32305ae |
Serial number | 5ed439fe-e689-11e1-88cd-0010f32305ae |
Bandwidth | |
Requested | 6000 kbps |
Allocated | 6000 kbps |
Route | DefaultSubZone -> DefaultSZtoTraversalSZ -> TraversalSubZone -> Zone001ToTraversalSZ -> TraversalZone |
Leg 1 | |
Bandwidth node | Default Subzone |
Source alias 1 | |
Target alias 1 | sip:loopback.sip@cisco.com (Url) |
Protocol | SIP |
Address | 151.124.146.111:5060 |
Transport | UDP |
Reason | Request Timeout |
Cause | 408 |
Leg 2 | |
Bandwidth node | TraversalZone |
Source alias 1 | source@domain.com (Url) |
Protocol | SIP |
Address | 205.214.144.152:7001 |
Transport | TLS |
Leg 3 | |
Target alias 1 | loopback.sip@cisco.com (H323Id) |
Protocol | H323 |
Address | 205.214.144.152:6001 |
Session 1 | |
Status | Failed |
Bandwidth allocated | 6000 kbps |
Bandwidth requested | 6000 kbps |
Channel 0 | |
Type | Audio |
Protocol | PCMU |
Rate | 0 bps |
Packets forwarded | 0 |
Keepalives | 0 |
Errors | 0 |
Duplicate packets | 0 |
Lost packets | 0 |
Out of order packets | 0 |
Jitter | 0 ms |
From |
Channel 1 | |
Type | Video |
Protocol | PCMU |
Rate | 0 bps |
Keepalives | 0 |
Errors | 0 |
Lost packets | 0 |
Jitter | 0 ms |
From |
Channel 2 | |
Type | Application |
Protocol | BFCP |
Rate | 0 bps |
Keepalives | 0 |
Errors | 0 |
Lost packets | 0 |
Jitter | 0 ms |
From |
Channel 3 | |
Type | Unknown |
Protocol | UNKNOWN |
Rate | 0 bps |
Keepalives | 0 |
Errors | 0 |
Lost packets | 0 |
Jitter | 0 ms |
From |
Channel 4 | |
Protocol | H224 |
Rate | 0 bps |
Keepalives | 0 |
Errors | 0 |
Lost packets | 0 |
Jitter | 0 ms |
From |
Session 2 | |
Status | Failed |
Bandwidth allocated | 5952 kbps |
Bandwidth requested | 5952 kbps |
08-14-2012 08:55 PM
I have the DNS Zone and I was able to resolve DNS names using the DNS tool
Using Tools/Locate from the VCS Control (endpoint registerd to the VCS Control)
Using Tools/Locate on the VCSE (not sure which source zone to use, used the Traversal Zone).
Note: IP Address 127.0.0.1 is the IP on the 2nd NIC on the VCSE (Its licensed for Dual NICs, but I'm not using Dual NICs).
The Ethernet interface has a public IP Address and directly connected to the internet.
Search completed. |
08-15-2012 03:39 AM
I have the feeling you did not really follow the standard deployment
I do not really see that the DNS zone is hit at all by your search, so there is most likely something wrong with your
dns zone, search rules or transforms.
Also do you expect to find "loopback.sip@cisco.com" on the second search I only see loopback.sip@compucom.com
To be honest, this looks like the typical "if you know how it shall work its fixed in no time." issue.
The back and forth in the forum is not really helpful, a hands on check would be way easier.
If you can not fix it yourself you should call your Cisco TelePresence partner and ask for help.
08-15-2012 09:34 AM
I accidentally typed in the wrong URI (meant cisco.com and not compucom.com). Compucom.com is the internal domain, so it wouldn't have searched/went to the DNS zone, that's why it appears the DNS zone wasn't hit.
I have set it up as per the guide you mentioned.
I edited my post with loopback.sip@cisco.com, back above, but here it is anyhow (from the VCSE from an internal endpoint), trying to reach the outside.
Search completed. |
thanks,
Paul
08-15-2012 09:57 AM
yea, but then we are back to what I said in the early begining,
either it does not find the proper dns records, or your firewall is blocking or changing the request.
03-16-2016 01:23 AM
Hello there;
I receive the same error on Cisco expressway to me. call falls on iOS does not fall "Call Rejected" is. I get this error every time. can you help me get it.
Error log:
tvcs: Event="Call Rejected" Service="SIP" Src-ip="10.1.1.1" Src-port="10006" Src-alias-type="SIP" Src-alias="sip:5000@10.1.0.32" Dst-alias-type="SIP" Dst-alias="sip:04a27964-e582-4801-3f29-bcb59c30d91a@10.218.156.67" Call-serial-number="932f3edb-e32e-4011-a1ea-55f69d2895b3" Tag="d5121b51-6ef1-4b8e-9c4b-7ff0acc474c1" Detail="Request Terminated" Protocol="TLS" Response-code="487" Level="1" UTCTime="2016-03-15 14:04:46,217"
11-02-2016 07:52 PM
We are getting the same Response code="487"
Did you ever resolve this? Cisco TAC has not been helpful in this case.
Thanks. Jordan
08-14-2012 10:42 PM
Just quick check, do you have DNS zone and any search rule pointing DNS zone in VCS Control?
For external URI dialing, DNS lookup should be done at VCS Expressway.
If you have any search rule on VCS Control pointing DNS zone, please remove it and try making outgoing external call.
08-15-2012 09:44 AM
Hi Tomonori,
Thanks for your reply.
I do not have any DNS Zones or any search rules pointing DNS zone in the VCS Control.
The only places I have the DNS lookup for external URI dialing is on the VCS Expressway.
See below....
VCS Control
VCS Expressway
Here's the VCSE DNS Zone Configuration and Search Rule
DNS Search Rule
thanks,
Paul
