Ports Usage between TP Infra and endpoints
Driss BENATTOU
Level 4
Level 4
I have TP Infra Behind Firewalla and endpoints distributed along sites.
I need all flows and interactions between endpoints and Infra (VCS, MCU, TMS). Otherwise, I have to know all TCP/UDP ports used between Infra and endpoints so that i have to open them at Firewall.
Driss
mahkrish
Level 3
Level 3
Hi Driss,
1. Please find the TMS ports utilization list.
2. For VCS port utilization you can refer to the following document.
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/config_guide/Cisco_VCS_IP_Port_Usage_for_Firewall_Traversal_Deployment_Guide_X7-2.pdf
3. For MCU port utilization you can refer to the following document.
http://www.cisco.com/en/US/docs/telepresence/infrastructure/articles/conferencing_products_conferenceme_ports_used_kb_3.shtml
HTH.
BR, Mahesh Adithiyha
