Presentation Source as Default Startup Screen
VCsupport17
Level 3
Level 3
Hello Community,
We have Webex Room 55 and we are using a Barco Clickshare for presentation. We want to make the Barco Clickshare to be always active as a video source on the Cisco room 55 so no need to press the presentation button.
Thanks.
You can set the behavior of the system when a presentation video source is connected on it.
Check the admin guide p.195 - Video Input Connector [n] PresentationSelection section.
You may set the presentation as Desktop mode. It says here:
Desktop: The content on the video input will be presented on the screen when you
connect the cable, or when the source is activated otherwise (for example when a
connected computer wakes up from sleep mode). This applies both when idle and in a
call. Also, the content on the video input will stay on the screen when you leave the call,
provided that it was the active input at the time of leaving.
You may also create a script for that for startup. Refer to Manage startup scripts on admin guide p230 on same link.
I hope this helps.
regards,
Ace
I hope this helps.
regards,
Ace
