05-23-2017 03:38 PM - edited 03-18-2019 01:08 PM
I have an Expressway deployment v8.9.2 with CUCM/IMP 11.5. We are using single-NIC and dual domain, one internal and one external.
We have our Unified Communication Traversal zone active. Expressway-C is pointing to the public IP address of Expressway-E.
When someone tries to log-in, Jabber asks for the password and, if wrong it says "password wrong...", but if right, it says "cannot locate the sever". I am receiving this error:
| 2017-05-23T17:26:22.486-05:00 | edgeconfigprovisioning: Level="WARN" Detail="Service not found for edge config response" Service="_cisco-uds" User="fmixtega" UTCTime="2017-05-23 22:26:22,485" |
| 2017-05-23T17:26:22.486-05:00 | edgeconfigprovisioning: Level="WARN" Detail="Service not found for edge config response" Service="_cuplogin" User="fmixtega" UTCTime="2017-05-23 22:26:22,485" |
1. My client doesn't have external.domain and internal.domain "folders" in their INTERNAL DNS server. So, the SRV records they have in their internal DNS server are: cuplogin, cisco-uds, sip, sips, h323 (all in internal.domian folder). Is it mandatory to have cisco-uds and cuploging in an external.domain folder in the internal DNS server?
2. For the peer in the Unified Communication zone we have expe.internal.domain which is resolved to the public IP Address. Could this configuration have an effect in this errors we are facing? With other clients I use to resolve the public IP address to expe.external.domain (example).
External DNS server are configured in Expressway-E and internal DNS servers in Expressway-C (DNS config).
05-23-2017 04:52 PM
For a multi-domain MRA deployment, take a look at Configure Mobile and Remote Access through Expressway/VCS in a Multi-Domain Deployment.
05-24-2017 04:43 PM
You don't need "cisco-uds and cuploging srv records in an external.domain" on internal DNS server.
But its important that the zone you are pointing to, that FQDN must be externally resolvable. For e.g. if i am pointing my UC traversal client zone to "exp-e.internal.domain", then this would be sent out to Jabber login via MRA over Exp-E, and when it tries to connection "exp-e.internal.domain" it might fail from public side and then jabber login will also fails.
Alok
12-17-2017 11:59 PM
12-18-2017 07:34 AM
Is MRA configured per the multi-domain example linked earlier in the thread?
12-18-2017 12:30 PM
08-02-2022 06:39 AM
Hi, I'm facing the same issue now, May I have more detail on DNS configuration? thanks
08-04-2022 12:06 AM
@ctohang99 Please have a look at the document that @Patrick Sparkman shared in his response as the information about what is needed in the DNS should be covered in it. If you still have questions or issues I suggest that you create your own post to ask your question(s) as that would likely get you a better chance of getting the help that you need.
12-18-2017 12:41 AM - edited 12-18-2017 12:42 AM
