12-27-2016 01:01 PM - edited 03-18-2019 06:44 AM
can you help me how to retrieve the release key for an update from 6.1 to s50000f9_3_4.pkg for a Edge 95 MXP
Solved! Go to Solution.
12-27-2016 02:28 PM
If you have a login on the Cisco support site, the serial number for your unit which is under maintenance then you should be able to get the release key.
12-27-2016 03:11 PM
If your device is covered by an active service contract, then you should be able to get one yourself through the Cisco Product License Registration portal.
Product Name : S50000
Product Qty : 1
Version : F9.3.3
Options Included Serial Number License Key Image URL
S50000 <Your Serial> 9999999999999999 null
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
12-27-2016 02:28 PM
12-27-2016 03:11 PM
Product Qty : 1
Version : F9.3.3
Wayne
