Replacing a touch device on a EX60
dgonzalez1
Hello, we had to RMA a touch device on a EX60 endpoing. Someone plugged the new one but it didn't go up automatically. Now, I am remotelly connected to the EX60 endpoint and I could see in Configuration --> Peripherals --> Touch screen device that it had configured the old device (based on the mac address). I tried to modify it but was no possible. So I removed that device, but now I don't see how to add the new one. Is there a procedure to add a new touch device? I can't find it in the guides.
Thank you,
Diego G.
6 Replies 6
Try to do a factory rest of  Cisco Telepresence touch screen controller and reconnect with the EX60. Hopefully EX60 will detect the new device automatically
You can refer below video for reseting the Touch Controller.
https://www.youtube.com/watch?v=9d2D8lox2_c
Response Signature
Thanks Nithin, we did the factory reset but there was no success.
The touch pannel stucks at this point as before:
What software release are you running on the EX - if you have one of the newer hardware versions of the Touch8 it won't work with some of the older TC software versions.   If you are running software release 5.1.4 or later, you shouldn't have an issue - but I'd suggest you re-upgrade the EX to a current software release just to make sure it's on current code, and it is able to provide the correct software to the Touch8.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Hi Wayne, I'm running software release s52000tc6_0_1 on the EX60.
The new touch hardware is this:
I tried upgrading the EX60 to s52000tc7_3_17 or s52000tc7_3_20 but it failed with error "/share/installimage/hooks.d/installimage-endeavour failed to run!" As I found, it could be due to HW incompatibility. Previous SW versions are unable to download.
Thanks.
From that photo, you have the wrong part.
The CTS-CTRL-DVC8 is a Touch 8 for a C Series or Profile Series.
The Touch 8 you will need for an EX is a CTS-CTRL-DV8.
Wayne
So that is the problem? It makes sense, the original touch device was CTS-CTRL-DV8.
Well, thank you Wayne, I'll try to replace it for the correct one.
