Resetting a 1700MXP with Menu password.
Visualcom23
I've just got a bunch of 1700MXP back from a customer and they have put a menu password on all of the systems and haven't documented what the password is. Now I need to access the settings in the systems to be able to reconfigure them. Is there any way of doing a factory reset or reseting the system when you don't have the password?
The systems are set to static ip-adresses as well so I can't access them through my network since it's the wrong ip-range.
6 Replies 6
Jens Didriksen
Level 9
Level 9
This from the TANDBERG knowledge base
quote
Remember to write down the Option and Bandwidth keys listed out before you execute this command.
From the API (Telnet, SSH or serial cable) enter the following command:
  • defvalues set factory
This will clear all settings on the system, reset the IP access password to TANDBERG, clear the Option and Bandwidth keys, delete the Phone Book directories and format the flash disk.
unquote
You can also do a "triple E reset" with Hypertermianl on boot using a serial cable.
When the system is starting up press “Ctrl” and “Break” simultaneously on your PC keyboard.
At the $ prompt type ‘eee’ followed by enter.
Again, do not forget to write down any option keys before doing this.
cheers jens
Please rate replies and mark question(s) as "answered" if applicable.
If you can connect to the system and issue the command that Jens write about, then you can just erase the MENU PASSWORD, no need to reset the system to factory defaults.
From telnet, ssh or serial console, type:
menupassword set ""
No more menu passwords.
Can you not connect using telnet or ssh, then you probably need to reset the IP PASSWORD
Using a serial console, type:
strictpassword off
ippassword ""
//Robert
From the built-in help of a 1700:
menupassword ?
usage: menupassword set
code - max. 5 digits
OK
strictpassword ?
usage: strictpassword
Can only be switched on if the password is already strict.
Strict password requirements:
Must be at least 15 characters and contain 2 lower case, 2 upper case,
2 numeric and 2 special characters.
3 consecutive characters must not be the same.
Must not be the same as any of the 10 last strict passwords.
OK
ippassword ?
usage: ippassword [LAN interface]
LAN interface - 1
password - Max 16 characters - use "" to remove.
OK
Thank you, this helped, problem solved! =)
Hi Olof Johansson
I would request you to mark your question as answered so that it will help other users in the community. Thanks.
Lavanya
Olof how did you get into the system to change the menu password?  New to this could you give me some instructions?
how do I get into the system to change the menu password?  New to this could you give me some instructions?
Thank You I will appreciated...
Erika
