Roomkit plus downgrade to TC version
salem
Can i downgrade roomkit plus software from CE to TC  version?
 You cannot downgrade to TC. You should use CE.
TC is compatible with SX and MX, not CS kit.
Response Signature
Wayne DeNardi
No - all of the newer model endpoints need to run the CE or RoomOS software - they cannot run the old TC software.   The TC software is no longer being developed, so it's highly recommended that, if you have compatible endpoint models, you migrate them from TC to CE.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
