06-01-2012 02:35 AM - edited 03-17-2019 11:15 PM
as there are still no translated User Guides available and we have to write them on our own, how can I catch a Screenshot from Touch 8" like Cisco does for orignal User guides?
This would also be very helpful for remote support. Anyway, best would be a remote control for the remote control
thanks
Tino
Solved! Go to Solution.
02-11-2014 08:03 PM
If you click the "Take new shapshots of Touch Panel" button, within a few secodns, you should see the snapshot appear below it.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
02-12-2014 06:33 AM
Can you navigate around the touch panel from here or do you physically have to do it on site then snap the image? I was hoping you could click through and then find what you want, snap the image and save it.
02-12-2014 03:51 PM
Hi Dave,
No, you cannot operate the touch panel via the web interface. It just allows you to see what it is currently showing (by taking the snapshot).
Wayne
02-13-2014 05:46 AM
Got it, thanks.
